It is currently Fri Aug 01, 2025 11:09 pm
PostPosted: Tue Jul 02, 2019 9:05 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
How do you guys avoid yellow stains on European spruce when using CA glue? I thought I was alone in this back when I used European spruce in builds, but I just saw another luthier's work and the yellow stain is just all over any place where CA was used (for example bindings, rosette, etc.). He said he had sealed the top with shellac prior to putting CA on the wood but still the CA penetrated the shellac and stained the wood yellow in such a way that no amount of sanding would remove.
Is it even avoidable? Or maybe just tint the top yellow to hide it...
Typhoon Guitars
PostPosted: Tue Jul 02, 2019 9:52 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Did he seal the rosette and binding ledges with shellac or just the top. This staining happens when CA gets into the endgrain. If he just sealed the top then cut his ledges there would be no protection from this issue. That said, we recently had a thread where this staining happened even though shellac was used so it may be a case that sometimes one "coat" is not enough.
Bryan Bear PMoMC
PostPosted: Tue Jul 02, 2019 10:30 am
Well, I used to just do one coat of shellac but you may have seen the recent thread I started where this happened to me as well. I think it's best to do at least two coats, some suggested 3. From now on I will be doing 3. But I have used this same method on many guitars and NEVER had a problem, till I did.
PostPosted: Tue Jul 02, 2019 12:02 pm
City: Tyler
I have always sealed my ledges with a wet coat of nitro. Never had it bleed and I flood with ca.
PostPosted: Tue Jul 02, 2019 12:10 pm
Glen, do you brush it on? I never would have thought of using nitro for this.
PostPosted: Tue Jul 02, 2019 12:16 pm
Or maybe a quick spritz of Deft? I'm interested, too.
PostPosted: Tue Jul 02, 2019 12:27 pm
3 coats 1lb shellac or 2 coats 2lb cut applied with a brush, in the channel and around, or on the end grain and top surfaces. Let dry between coats.
PostPosted: Tue Jul 02, 2019 4:00 pm
First name: Gary
Last Name: Leddington
I had this on my first build... broke my heart... Over time the wood darkened to hide it and wit euro spruce this works well as aging tends to be yellowish as opposed to the golden orange of sitka say... anyway...
These days i do not go near a top with CA glue... i use a cellulose glue for rosettes (Duco in the states, UHU hart in Europe)... and i use titebond for binding / purfling.
G.
www.leddingtonguitars.com
PostPosted: Tue Jul 02, 2019 7:22 pm
City: Tyler
No I just spray a wet coat full strength, not thinned. McFadden/seagraves.
Users browsing this forum: No registered users and 42 guests
